Mixed-up symbols
So, I just picked up the CC3 Pro, and I'm not real familiar with programs like this. In fact, I'm not the most computer savvy guy out there, so sorry if I use the wrong terms.
I know I must have screwed something up somewhere... because I keep getting the wrong symbols in the wrong map styles. For example, I have Mike Schley's Mountains showing up whenever I try to use the CC3 Standard map style. and When I open the Mike Schley, in the mountains I have... well I have 2 trees and some vegetation terrain from Johnathan Roberts. I don't know if I should just re-install or not.
Does this happen when you start a new map using the new map wizard too, or just in your current map. For example, if you start a brand new Mike Schley overland map, do you get the right symbols then?
It's whenever I start one.
Sounds like your filters may be messed up. Have you edited and saved any of the master filters (accessible by right clicking Symbol Style Toggle
and picking Master Filter), or changed and saved any catalog settings (accessible from Symbol Catalog Settings
and then clicking advanced in the dialog)?
I'm going to be honest... I don't know. I know I was using that button, and messing around with things, but I don't know if that was one of the things I hit. From what I have read up on, that does seem to be the most logical answer.
If it is the filters, I think a repair install will fix it since it should replace changed files. Can you try just to run the original CC3+ installer again and it should offer you a repair option. See if that fixes things.
Note that each time you test if things work as they should always test by creating a brand new map, since the map controls which filters to load.
Thanks! I'll try that tonight.
Sadly, that did not work.
I uninstalled, and reinstalled, and it seems to be working now.
