Text Size
Having serious problems reading anything in the list box as the text is far too small to read. I've tried right clicking the upper left control box and choosing large text but it doesn't change the size of the text in the window even if you pull up a new list window.
Hopefully there's a way to make this bigger as it's pretty much impossible to read as it sits.
Unfortunately, no. That window doesn't play nice with Windows display scaling (I guess you are using a 4K monitor with 200% display scaling or similar?).
A workaround here is to just copy the text to the clipboard (save to clipboard in the control menu) and paste it into notepad or something else where you can control the text size. A bit of extra work that, unfortunately, but at least you have full control of the view then.
Yeah 27" iMac running bootcamp. Well, I was hoping but 🤣
