Changing color for Vegetation in DD3 symbols.
Hello,
I am trying setup a couple of trees on a Dungeon (made of metal). One should be Silver in color and the other should be Gold.
However, when I change the color of one, it changes the color of the other one.
I've tried to put them on separate sheets, that did not work, neither did separate layers.
How can I set both items to be separate colors?
Best Answer
    Accepted Answer
    I can't reproduce this.
    When you change the colors of the trees, are you actually editing the color in the palette? If you do that, you'll need to use a different color position for each tree, the palette in CC3+ is an indexed palette with 256 colors, so you cannot reuse the same color slot for different colors, if you do that, you would see all the entities using that color slot change at the same time.
    Also, to make palette changes stick, make sure to re-attach it to the drawing after changing it, using the Attach to Drawing button in the Drawing Properties dialog.
Answers
