map borders
Aramisdante
Newcomer
Can you import your own map borders, the ones that outline your map not the kingdom borders and if so, how. I have searched high and low on youtube and can't seem to find the video to show my how
Sure. If you have them as an image file, just use Draw -> Insert file to insert it into the drawing (Note that CC3+ inserts a reference to the file, so if you later move or rename it, your map will display it as a missing image).
If it is a tiling texture, you can import it as a fill style from your map (Tools -> Import bitmap fill style or just create it manually from the fill style dialog) and you can then use it as a fill when drawing things like polygons.
Thanks that was helpful
Question Monsen, If I hit the flag button does that allow me to keep this post or does it report you. I DON"T want to report you but I would like to hold onto this info
Sincerely Aramis
Flag is used to report a post. You can bookmark a thread by clicking the star in the top right corner of the top post.
ok thanks glad I asked
I've used the flag a couple of times on spam posts. It gives you a dialog that you have to interact with to complete the job, so you can't really accidentally report anyone. Don't worry :)
