Cloud Cover
Hello,
Recommendations on how to add cloud cover over a section of an overland map?
Thanks!
    edited December 2020
    It's not generally done, but easy enough.
    Add a CLOUD sheet above all but the TEXT sheets, and add a largish blur effect to it. Then either add circles of pale colours (not all white), and/or use the freehand drawing tool with a line width set above zero to scrawl on that sheet in similar off-white colours.
    Here is the smoke from a chimney stack done using scribbles and a blur.
    [Deleted User]MonsenTerennWyvernWeathermanSwedenDaishoChikara
  • Sue's advice is excellent for adding your own clouds.
    If you might be interested in using symbols instead - or as well as - you may like to see the Alyssa Faden style pack, which was part of the Cartographer's Annual in 2014, as that comes with a number of cloud symbols designed specifically for use on overland maps.
    JimPLoopysueDaishoChikara
