CD3 House Settings - Not showing CA63 fills
I'm trying to build a custom House Setting to include the fill styles found in the CA63 folder, but those options are not listed in the House settings dialog box. I only see CD3, CD3A, and CD3B styles. How can I add the CA63 styles to this area so I can build houses with that style?
Thanks much!
That list shows the fill available in the current map. If you want fills from another style you need to import them into the map first, then they will be available to pick from that dialog.
