Changing color settings
Hi folks, total noob here. I did some searches before I posted this, but the truth is I don't even know how to frame this question in the proper terms, so I'm not even sure what to search for.
I am creating a series of hex maps of different scales. The overall world map, I began using the basic overland style (Overland CC3 Hex). I later discovered the Annual Hex Overland package, and used that for a regional map. I then went and replaced the symbols on the world map with the Annual symbols, only to realise some time later that the colors are noticeably brighter... too bright.
For the life of me I can't figure out how to change the settings so that the color/contrast is the same as for the Annual Hex style. Surely there's a simple setting I can tweak?
Thanks in advance folks, and sorry for the super basic question.
You can try adding an RGB Matrix effect to the whole drawing or just selected sheets. See the attached screenshot (pre-defined RGB Matrix settings are located in the CC3+ program data folder under filters/settings/).
