CD3 Bogging Down
I'm finally getting a chance to get back to mapping and have been playing around with CD3. When I first open the map everything works fine. However, the longer I work, the longer it takes to redraw a screen. This is a gradual slowdown, going from a fraction of a second at the beginning to taking almost three minutes after a half hour of mapping. It eventually just locks up my system. I never noticed this problem before installing CD3 and do not see this when working on a CC3 or DD3 map. I believe I am up to date with patches (v3.24).
Laptop: Pentium Dual-Core 1.73 GHz, 1 gig Ram, Win XP Home SP3
Any ideas why this is happening?
    WinXP SP3 has many of the items that Vista has. I don't think it runs well in only 1 gig of ram.
  • Posted By: JimPWinXP SP3 has many of the items that Vista has. I don't think it runs well in only 1 gig of ram.
    Sorry, you've confused me on that. What doesn't run well on 1 gig of ram, XP or CD3?
    Xp runs just fine. CC3 runs just fine. DD3 runs fine too, as do all of my other software (Paintshop pro, Photoshop, Realdraw, etc). Does CD3 have a higher ram requirement than the core CC software? I'm not being snitty. Just confused by your comment. :)
    I am saying many of the things that are in Vista are ram hungry. I have a Vista computer with 3 gigs of ram, and things still slow down.
    I had a WinXP computer with 1 gig of ram, and SP 2. It ran slowly when I made maps. I upgraded it to 1.5 gigs, big jump in speed. I later upgraded it by removing the 512 meg, and put in 1 gig. Much better response.
    So I am saying the slow down might be not enough ram in your computer.
  • Since I have no intention of rolling back the OS or of upgrading this laptop,I suppose my best choice is to do a reinstall of just CC3 and DD3 and do my cities with Photoshop. Kinda stinks since CD3 has features that I love, but as it is now, it's unbearable to work with.
    Thanks for taking the time to respond Jim.
  • CD3 needs a pretty powerful computer I think... I recently purchased a beast of a machine and CD3 now runs quite smoothly. On my bigger maps loading effects can still take 10 to 20 seconds though :-)
    edited July 2009
    Ah, I see now. I have a WinXP laptop with 512 megs of ram. i can do overland maps on it, but not cities nor dungeons. I didn't notice your mention of laptop.
    You should always work with effects off. To increase speed further, look at the Display Speed settings and disable the aligned fill styles.
    This should increase the speed enormously until you are ready to export.
  • Simon, I always work with effects off, however, disabling the aligned fill styles helps a lot. That one change has taken city mapping from unbearable to tolerable. If there are other tweaks that could get a little more speed for me I'd love to hear them. Thanks!
  • Ya for me it likes to just really lag when I check out already created cities. then it pops the FastCAD error and asks if i want to report it.
    So I'm guessing this is a video card problem?
    I am uncertain about that Dasaki. But I do know my desktop has a 3d card, while my laptop has integrated video chip on the motherboard.
    edited July 2009
    Posted By: ShessarSimon, I always work with effects off, however, disabling the aligned fill styles helpsa lot. That one change has taken city mapping from unbearable to tolerable. If there are other tweaks that could get a little more speed for me I'd love to hear them. Thanks!
    Make sure you have lots of free memory by closing down other apps and any unecessary memory-hogging tasks (updaters, for example)
    Hide all layers and sheets you aren't working on and don't currently need to see.
    On Display Settings Select Fixed Bitmap Quality and choose Low (Very Low is probably not bearable, but you could try that)
    Make sure "use memory cache for bitmaps" is on and make sure it's set to -1.
    Disable shading
    Try "Draw aligned fill styles as solid", too.
    If you do fixed bitmap quality and zoom extents so that every bitmap image in your drawing is in memory, after the first zoom, you'll find the speed much increased.
    Right click display speed settings, select Global Sun and deactivate Lighting, too.
  • edited July 2009
    Choosing the lower bitmap quality had the most impact as well as looking at what programs were memory resident. Dell had a speech recognition program sitting in memory that I never even realized was there. Dumped it, heh!
    I'm actually able to map in CD3 at a reasonable pace now. I worked for two hours last night without any major slowdowns. Once again, thank you Simon! The PF staff again shows its fantastic customer support.
