Rendering images to jpg or png crashes
I'm having trouble rendering a map I drew. It gets to one of the last iterations of the render, and crashes on the contours layer consitantly, but I don't see anything on that layer. Can anyone help?
    edited October 2020
    Can you share the FCW with us so that we can have a go at crashing it too?
    Also a screen shot of the options settings, so that we can replicate the problem.
  • IthrilIthril Traveler
    Here they are.
    The hardware I have should handle this without any trouble.
    Thank you for taking a loook at it.
    I
    There is something up with the entity in the bottom right corner on the TERRAIN GRASSLANDS sheet. I couldn't even open CC3+ with your map in a maximized window without it crashing immediately.
    I was able to fix it by simply running the SIMPLIFY command on the entity with a simplification distance of 1. I didn't look too closely, but this didn't seem to affect the entity visually except the loss of the bottom right corner which needs to be remade using the Insert Node command, but doing that immediately stopped the crashing for me.
    Loopysue
    Awesome!
    I used the remove nodes command from the explode menu twice for good measure on that entity, and it seems to have resolved the issue.
    Thank you very much!
    I
