How do I find out a symbols current color?
When I use Change Properties, I'll get a dialog that shows current/active color for the sheet, which is really handy if I want to change the symbol's color to that. But how do I find out what the symbol's current color is?
Best Answers
    Accepted Answer
    You can find that and a lot of other information as well by using the List command in the Info menu.
    Pick List, and then select the symbol and press D for do it. That will bring up a blue window with all the relevant details.
    argel1200
    Accepted Answer
    An additional tip here is that you can use Extract Properties on the entity. That changes the current color to that color (as well as other properties). This is great when you need that to be the default choice in change properties for changing other entities to match. It also lets you see the color visually on the status bar.
    Loopysueargel1200
Answers
