Creating a specific arc width?
I'm drawing charts where I need arcs starting at a particular point (often arbitrary) but with set arc widths (ie how many degrees the arc runs for). At the moment, I'm using Center, Start and End and just starting the arc and then using Numeric Edit to set the exact arc width. Is that the quickest way to do it, or is there a method that can set it while you're placing the end point? Thabks in advance.
EDIT: I'm an idiot, ellipse is what I was after. Making it worse, I think I've used it in the past.
