City Walls Macro - can someone get this to work?
Here is a city macro I found that is supposed to draw really cool city walls that I would love to have in my toolbox for CC3Plus.
Trouble is, I cannot get it to work - can any of our macro experts help here.
INSTRUCTIONS
CITYWALL3
This macro prompts for several items of information, then allows the user to select a series of points. The macro draws a city wall between each point, and inserts a tower on top of each point. The appearance of the wall and towers depends on the provided information (default values in brackets):
1. Wall width. (10)
2. Parapet both sides? (Both)
3. Parapet width. (2)
4. Tower width. (Wall width x 2)
5. Tower style. (square or circle) (circle)
6. Roof style. (flat or peaked) (peaked)
7. Roof walkway width. (5) (Optional: if 'peaked roof' is selected)
All of the macros found in the 'Code' section below are required, but only the macros "CITYWALL3' and 'CITYWALL3TOWER' should be run from the command line. For best results, create a separate macro file for the macros here, and load that file when you need to create city walls.
NOTES:
1. Left clicks draw wall segments, right click to end the wall.
2. Square towers automatically align themselves at an angle midway between the two adjacent walls.
3. Walls will enter and exit a square tower on opposite sides of the tower when the difference in angle between the two walls is less than 55 degrees. Angles greater than this will cause the walls to enter and exit the tower on two adjoining sides of the tower.
4. Parapet widths apply to both the wall and the tower. Towers with peaked roofs will still have a parapet.
5. The minimum size for a tower is equal to the selected wall width, but for best results, select a tower width at least two times that of the wall width.
CITYWALL3TOWER
This macro draws only a tower, located at the point specified. After prompting the user for several items of information, the macro prompts for the tower location point. If a square tower style was selected, the macro also prompts for the tower orientation. The appearance of the tower depends on the provided information (default values in brackets):
1. Tower width. (20)
2. Tower style. (square or circle) (circle)
3. Roof style. (flat or peaked) (peaked)
4. Roof walkway width. (5) (Optional: if 'peaked roof' is selected)
  • Code
    ________________________________________
    //Morgan Olden (June 2000)
    macro CITYWALL3
    ecoff
    rdoff
    gv ColDS 18
    gv ColLS 16
    gv ColDR 11
    gv ColLR 10
    gv WW 10
    gv sides 1
    gv TWW 5
    gv TS 1
    gv RS 0
    gv WW ^DEnter wall width:
    gv sides ^DParapet on both sides? (one side=0, both=1)
    gv TW WW*2
    gv TW ^DEnter tower width:
    ifn TW-20 control1
    go control2
    :control1
    gv TW 20
    :control2
    gv TS ^DChose tower style (square=0, circle=1):
    gv RS ^DChose tower roof style (peaked=0, flat=1):
    ifz RS askwalkwaywidth
    go skipwalkwaywidth
    :askwalkwaywidth
    gv TWW ^DTower walkway width (defalt=5, none=0):
    :skipwalkwaywidth
    gp P1 ^DFirst point:
    line P1 ^DNext point:;
    gp P2 @0,0
    selbyp;erase;
    gp wallpoint1 P1;gp wallpoint2 P2
    drawwall3
    gbrng towerbrng P1 P2
    gp towercenter P1
    drawtower3
    :loop
    line P2 ^DNext point:;
    gp P3 @0,0
    gdist testdist P2 P3
    ifz testdist laststep
    selbyp;erase;
    gp wallpoint1 P2;gp wallpoint2 P3
    drawwall3
    gbrng B12 P1 P2
    gbrng B23 P2 P3
    gv towerbrng (B12+B23)/2
    gsin offset (B12-B23)
    ifp offset control5
    gv offset 0-offset
    :control5
    ifn offset-.8 control6
    gv towerbrng towerbrng+45
    :control6
    gp towercenter P2
    drawtower3
    gp P1 P2;gp P2 P3
    go loop
    :laststep
    |gp towercenter P2
    drawtower3
    selbyd
    econ
    rdon
    endm
    macro DRAWTOWER3
    ifz TS drawsquaretower
    :drawcircletower
    lwidth 0;color ColLS;fstyle solid;cird TW towercenter;
    lwidth 1.5;color ColDS;cird TW towercenter;
    color 0;fstyle hollow;cird TW towercenter;
    gv OutsideTW TW+.75
    gv OutsideCirc OutsideTW*3.1416
    gv counter 0
    :circcounterloop
    gv counter counter+1
    gv OutsideCirc OutsideCirc-7.5
    ifz OutsideCirc donecirccounterloop
    ifn OutsideCirc-7.5 donecirccounterloop
    go circcounterloop
    :donecirccounterloop
    gv OneArcUnit 360/counter/7.5
    gv currentangle 0
    :circcrenloop
    lwidth 2.5;color ColDS;fstyle solid
    arcr towercenter OutsideTW/2 currentangle (currentangle+(OneArcUnit*5))
    |gv currentangle (currentangle+(OneArcUnit*7.5))
    ifp currentangle-360 donecirccrenloop
    go circcrenloop
    :donecirccrenloop
    ifz RS circlepeakroof
    :circleflatroof
    go done
    :circlepeakroof
    lwidth 0;fstyle solid
    color ColLR;cird TW-(TWW*2) towercenter;
    color ColDR
    arcw towercenter (TW-(TWW*2))/2 200 350
    |color 0;fstyle hollow;cird TW-(TWW*2) towercenter;
    go done
    :drawsquaretower
    gp TP1 ref towercenter <towerbrng+45,TW*.70711
    gp TP2 ref towercenter <towerbrng+135,TW*.70711
    gp TP3 ref towercenter <towerbrng+225,TW*.70711
    gp TP4 ref towercenter <towerbrng+315,TW*.70711
    lwidth 0;color ColLS;fstyle solid;poly TP1 TP2 TP3 TP4;
    lwidth 1.5;color ColDS;poly TP1 TP2 TP3 TP4;
    color 0;fstyle hollow;poly TP1 TP2 TP3 TP4;
    gp TP1 ref TP1 <towerbrng+45,.5303301
    gp TP2 ref TP2 <towerbrng+135,.5303301
    gp TP3 ref TP3 <towerbrng+225,.5303301
    gp TP4 ref TP4 <towerbrng+315,.5303301
    gdist DTS TP1 TP2
    gv DTS DTS-12.5
    gv remainder DTS
    :remainderloop
    ifz remainder doneremainderloop
    ifn remainder-7.5 doneremainderloop
    gv remainder remainder-7.5
    go remainderloop
    :doneremainderloop
    gv CrenBrng towerbrng-90
    gp Cren1 ref TP1 <CrenBrng,(remainder/2)+7.5
    gv CrenTDist DTS-remainder
    path ref TP1 <CrenBrng-90,5+(remainder/2) TP1 ref TP1 <CrenBrng,5+(remainder/2);
    DRAWCRELLELATION
    gp Cren1 ref TP2 <CrenBrng,(remainder/2)+7.5
    path ref TP2 <CrenBrng-90,5+(remainder/2) TP2 ref TP2 <CrenBrng,5+(remainder/2);
    DRAWCRELLELATION
    gv CrenBrng towerbrng+90
    gp Cren1 ref TP3 <CrenBrng,(remainder/2)+7.5
    path ref TP3 <CrenBrng-90,5+(remainder/2) TP3 ref TP3 <CrenBrng,5+(remainder/2);
    DRAWCRELLELATION
    gv CrenBrng towerbrng+180
    gp Cren1 ref TP4 <CrenBrng,(remainder/2)+7.5
    path ref TP4 <CrenBrng-90,5+(remainder/2) TP4 ref TP4 <CrenBrng,5+(remainder/2);
    DRAWCRELLELATION
    ifz RS squarepeakroof
    :squareflatroof
    go done
    :squarepeakroof
    gp TP1 ref towercenter <towerbrng+45,(TW-(TWW*2))*.70711
    gp TP2 ref towercenter <towerbrng+135,(TW-(TWW*2))*.70711
    gp TP3 ref towercenter <towerbrng+225,(TW-(TWW*2))*.70711
    gp TP4 ref towercenter <towerbrng+315,(TW-(TWW*2))*.70711
    lwidth 0;color ColLR;fstyle solid;poly TP1 TP2 TP3;
    color ColDR;poly TP3 TP4 TP1;
    line TP1 TP3;
    line TP2 TP4;
    color ColDR;fstyle solid;lwidth 1;line towercenter TP4;
    color 0;fstyle hollow;lwidth 1;line towercenter TP4;
    color ColLR;fstyle solid;lwidth 1;line towercenter TP2;
    color 0;fstyle hollow;lwidth 1;line towercenter TP2;
    color ColLR;fstyle solid;lwidth 1;line TP1 TP3;
    color 0;fstyle hollow;lwidth 1;line TP1 TP3;
    go done
    :done
    endm
    macro DRAWWALL3
    color 0;lwidth 0;fstyle solid
    gbrng B12 wallpoint1 wallpoint2
    gdist Dist12 wallpoint1 wallpoint2
    gp L1 ref wallpoint1 <B12+90,WW/2
    gp R1 ref wallpoint1 <B12-90,WW/2
    color ColLS;lstyle solid;fstyle solid;lwidth WW;line wallpoint1 wallpoint2;
    color ColDS;lwidth 1.5;line L1 ref L1 <B12,Dist12;
    line R1 ref R1 <B12,Dist12;
    color 0;fstyle hollow;line L1 ref L1 <B12,Dist12;
    gp Cren1 ref L1 <B12+90,.5
    gv CrenBrng B12
    gv CrenTDist Dist12
    DRAWCRELLELATION
    ifz sides done
    gp Cren1 ref R1 <B12-90,.5
    gv CrenBrng B12
    gv CrenTDist Dist12
    DRAWCRELLELATION
    :done
    endm
    macro DRAWCRELLELATION
    gp CrenS Cren1
    :loop
    gp Cren2 ref Cren1 <CrenBrng,5
    lstyle solid;color ColDS;lwidth 2.5;fstyle solid;line Cren1 Cren2;
    color 0;fstyle hollow;line Cren1 Cren2;
    gdist CrenDist CrenS Cren2
    ifn CrenTDist-CrenDist-7.5 control1
    gp Cren1 ref Cren1 <CrenBrng,7.5
    go loop
    :control1
    endm
    macro CITYWALL3TOWER
    ecoff
    rdoff
    gv ColDS 18
    gv ColLS 16
    gv ColDR 11
    gv ColLR 10
    gv TWW 5
    gv TW 20
    gv TS 1
    gv RS 0
    ifn TW-20 control1
    go control2
    :control1
    gv TW 20
    :control2
    go loop
    :askwalkwaywidth
    :loop
    gp towercenter ^DPick tower center:
    iferr done
    ifz TS-1 control3
    line towercenter ^DTower angle:;
    gp anglereference @0,0
    selbyp;erase;
    gbrng towerbrng towercenter anglereference
    :control3
    drawtower3
    go loop
    :done
    selbyd
    econ
    endm
    edited August 2020
    What exactly is the name of this macro and what is it supposed to do? Where did you find it?
    EDIT: I spent time looking for it while you were editing your posts. Sorry. There is a apparently a "drawwall3" macro that you haven't defined that does the real work of actually drawing the wall segment.
  • I got it from the now defunct download section where people put up some of their work'
    It is supposed to draw city walls as above
    What seems to be the problem with it? I just pasted it into my macro file, and it worked perfectly fine (except that it uses lighter colors than in the screenshot)
    (Note that the code visible in Quenten's post isn't complete, when the forum sees a pair of < > it thinks it is an html tag, and hides it, you need to check the actual source)
    edited August 2020
    It might be better to attach the macro files than paste them in the text. Put them in a zip archive and don't forget the "DRAWWALL3" macro since it does the real work of actually drawing the wall segment.
    ERASE is a standard macro in CC3+.
    If it isn't available, it will be for one of these reasons:
    - You've edited the macro file improperly. Your new macros may not be properly terminated with ENDM or have extra ENDM in them, or you've accidentally messed up something else int he file when editing.
    - You've unloaded the standard macro file.
  • It may be that the macro does something to the standard file, because very few of my button commands work after.
    Could you recheck that it does work on your system, ie the one in the zip file, please? There are no missing or extra endm.
    And the file is exactly as is in the zip file - I have not edited it at all.
    Does there need to be a blank line after the last endm? (there is in the macro I have)
    Sounds to me like you are unloading your default macro file. You aren't using the LOADMAC command, are you?
    Well, that's your issue then. Loading another macro file unloads the current one, effectively disabling all the default macros.
  • When you want to use new macros you need to add them to the old (default) macro file (after saving a backup of the old file of course) so they can use any existing macros. I vaguely remember that a custom macro file in the same directory as a map file will automatically override in the one in the CC3PLUS data directory. Is that still right?
    Yes, a macro file with the same base name as the map file will automatically be loaded when the map is loaded. Be aware when using this though, because this stays loaded as long as the program runs, the default macro file isn't loaded back with the next map.
  • Thanks, I didn't know that.
  • Is there a way I can load custom macros eg like this one, separately and still have the default macro run. With other macro i use a lot (mtns, tiles and star), I can load these separately and the default macro still runs.
    I would make a copy of the main macro, and put it somewhere completely outside the Profantasy folders.
    You could then edit the main macro in the Profantasy folder, with additional parts.
    Load and unload the additional macros with the main bit in them.
    That way you have a copy of the main macro unedited. And make backups of your changed ones to. In case an update writes over the copy in the cc3plus folder.
  • Yes, I already have done that - I just hoped I could keep it as separate. Ah well.
  • OK, I have got it to work - which will save me heaps of work.
    Next mission: How can I get it to put the white part of the walls onto the sheet Walls bottom, and towers onto towers bottom, all the crens on the sheet Walls crens, and the tower roofs onto tower roofs, and all the lines underlying the crens onto crens bottom.
    Sorry to be a nuisance, but I have 3 excuses:
    1. I am hopeless with programming.
    2. I want more than I asked for
    3. I am an Aussie, so I have to think while standing on my head and being knocked down by kangaroos onto horrid wet sand. 3:)
    To put things onto different sheets, you just have to make the macro switch sheets at the relevant places.
    you can use the command GOSHEET for that. For example, GOSHEET WALLS will switch to the WALLS sheet (and to avoid errors in the macro, will also create it if it doesn't already exist)
  • I'll give it a go, but i bet I'll need your or Dalton's expertise later on.
