Help with Bridge tool
Fairly new to CC3+, and I'm having some troubles with the Bridges in DD3.
I have a long bridge over a chasm so placed a start and end, then when placing the middle sections the bridge doesn't connect together, leaving small gaps between every piece.
Am I doing something wrong? I don't get the issue if i use the wooden bridge, but both stone bridges have the issue?
Anyone got a fix for this?
Thanks
    For that bridge symbol, I recommend not using the connecting symbol at all, but rather to turn on snap (and cursor snap) and place them with a bit of an overlap (Try using a 4.5 foot snap grid instead of 5). Place the two ends last.
    You can draw it without the connecting symbol by temporarily disabling smart symbols. When you have the symbol on your cursor ready to place, right click in the drawing, and in the symbol parameters dialog, enable the disable smart symbols option.
  • Thanks Monson, that's perfect.
    bridge is now all connected.
