Missing menu_recovery.bat
So I'm trying to install Vintyri.
I followed the install instruction until the point where I supposed to run the menu_recovery.bat, because I can't find it. I have hidden files shown etc so that won't be the problem.
It's neither in the data or programm folder.
I just did a test install to confirm, and it is showing up in the root of my data folder at c:\ProgramData\ProFantasy\CC3Plus.
If it isn't there, it seems like the installer may not have copied the file correctly. In that case, more files may be missing, so I suggest running the installer again. Make sure to use the latest version from the website (latest version was released October last year, it seems), and to be sure, right click the installer and choose the run as admin option.
Edit:
I just ran the updatefile over it and with that the bat file showed up. Thanks for the tipp now I hope the toolbar will show up.
The menu_recovery.bat is something they add, it isn't a standard CC3+ component.
