DXF paths messed up after using "Change like draw tool"
I have trimmed some road SHP files and saved them as DXFs. When I load them into a map and position+scale them, they look fine!
Then I go to style them, any change that changes the thickness causes them to generate weird geometry artifacts, typically in the form of random lines of varying thickness draw on random parts of the map.
In this first post is a pic showing the lines before thickness modifications.
