Starship Deck Plans - Boeing Starliner 1701 Main Body
This is for a near future setting. In-System Passenger Liner: two maps - the first is the central body; the second is the passenger ring which spins about the central body for artificial gravity. I am aware that the biology and physics of rotational bodies require a much larger ring to correctly simulate earth gravity without causing people to get dizzy or messed up by the coriolis force but... bear with me - some willing suspension of disbelief please. Plus it's my first map so... go easy. :-)
Docking bay is on the Main map (black/yellow inset). As for the side on views - I'm not sure what plan view is or how to access it but I'll look into it. I found it difficult to convey a 'side-on' view of the ring so if there's a better way to do it, I'm all for it. I also initially did the math for the ring measurements but I think it ended up going out the window as I tried to get scales correct. :-\
You can get the second line of text for area 9 to line up with the others by adding spaces to the second line, though that may need a bit of trial and error. Both this and adjusting the line numbering can be done using Edit > Text > Edit Text using the drop-down menus, incidentally.
Shocked that it's not Pan-Am, obviously, but I gather Kubrick guessed wrongly, without a time machine to check its then-future survival as a company...
Nice-looking map though. Maybe a bit more wall clutter in the zero-g crew room (area 3) to make navigating it a bit easier?
Thanks for sharing!
I'll noodle on it and maybe get past my OCD. Maybe. :-P
Amusingly enough, my mom actually worked for Pan Am back in the day and she feels a fierce amount of corporate loyalty to a company that no longer exists. Debated for an entire evening who to put as the manufacturer. Initially thought about an amalgamation between Boeing and SpaceX. Considered Northrop Grumman and/or Lockheed/Martin or combos thereof. Finally decided to just go simple and leave it at Boeing since they already actually have a Starliner in development. Obviously tacked on the 1701 as an homage.
Yah Area 3 is a little plain. Will spruce it up a bit.
I'm working on the habitat ring making it thinner and more 'aligned'. Also adding lifeboats (another thing I had also previously considered) to the side of the main body. Will re-post when complete.
The font is called Oceanic Drift.
- "P" - the central passage is 5.5 feet wide between bulkheads and 8 feet tall between the ceiling and the lattice decking which can be opened to access the crawlspace (C) below for maintenance.
- "E" - the elevator and shaft provides easy access between the core ship and the ring. The elevator capsule itself can be ejected as a short term emergency life pod with a maximum capacity of 4 adults and 48 man-hours of life support.
- "L" - opposite the elevator is a ladder tube that has airtight hatches between decks. On the "Bilge" level it can serve as a one-person manual airlock that may have a lifeboat attached.
- "R" - the outer rooms of the ring have 9.5 feet of head room and are typically 15 feet wide and 21 feet long. (The vertical access tubes aren't present between the spokes.) Note the floor of Inner (Upper) Deck rooms are 18" below that of the passage and require two steps down at the hatch.
- "Attic" and "Bilge" decks are filled with life support and other machinery and can be accessed by the crawl spaces ("C").
I'm still working on the deck plans for the Inner and Outer ring decks and have some interesting ideas for those.I like what you did with the decking backgrounds - nice work with the elevator. My only thinking on the life pod was, in the vastness of the Solar System, you're lucky if rescue is weeks away. I'd want more than two days. I realize at this point it's semantics since you can say the pod provides however much life support you want.
I actually didn't pick any one symbol set - I went with whatever symbol I happened to like best for the given object I was trying to convey. That ended up being the Sci-Fi vector sets 9 times out of 10 but every once in a while (closets, cabinets, and a console or two) I went with Sci-Fi Bitmaps.
Keep at it - I want to see what it looks like with the floors decked out (pun totally intended). :-)
