Copying object between 2 sheets
Hello,
I'm trying to follow the tutorial CA 155, but I'm stuck at the step7 : making the Frame. More specifically I try to copy the background rectangle on to the
FRAME sheet, but the paste is always done on the BACKGROUND sheet.
My procedure is : Select BACKGROUND sheet -> copy the object (ctrl+c + selection + do it + origin select) -> select FRAME sheet -> paste the object (ctrl + v + click anywhere).
If someone has any idea of the problem...
thanks
thanks
Select the frame.
Right click Do it.
The Sheet selection popup comes up.
Select the sheet you want to move it to.
Click okay.
If you have a hard time selecting just the frame:
1) do a List command and select the frame and what ever else is selected.
2) Look for a tag # for the frame.
3) close the list window.
4) right click anywhere in the map area. Go down to More -> and select Entity Tag #
5) type that tag #.
6) the command line will now say 'select entities, (1 selected) enter key
7) right click anywhere, and select Do it.
8) select the sheet you want to move it to.
9) click okay. All done.
