If you add more names it will become messy. At that point it would be better to have a legend down one side, which would mean a few major adjustments to allow space for it. So it's up to you if you go that far.
I just wanted to send a reminder to certain people to map their namesake if possible.
Wyvern and I have/are already doing so. Shessar started mapping Shessaria, but I don't know what has happened to that.
Monsen, why not do another city, about 5-10,000 pop, for your city of Monseignor (probably a religious city with lots of religious sites?). You must have lots of spare time/
C Lithgow - great if you could do a magnificent lighthouse, a beacon of Hope for these dark times.
Sue, I know you are busy, but how about a quick island in one of the recent styles?
Ralf, we really need a new ship style, or a video on the old ship style. How about doing your wreck?
Jim - we need one of your magnificent dungeon styles for a dwarf stronghold - perhaps a complex 3D one?
Lorelei, a beautiful shrine is definitely required - perhaps dedicated to St Strmpfy (obviously Polish)?
Just a couple of quick thoughts regarding Monseignor city, as I've been jotting a few notes down regarding the villages and other points of interest I've set nearby to go with the whole Wyvern Citadel Defence Zone concept, including one village as its deep-water port on the southernmost channel of the rivers running into the nearby delta, because the city didn't seem to be set close enough to the sea or the delta otherwise when I started mapping the region in more detail. Nothing's completely finalised yet, but just a heads-up in case these might have a bearing on the appearance of the city by the time the texts hit the Atlas ?
You are the boss of that region. Bear in mind that Shoenia is a regional map; yours will cover a much smaller area in greater detail, so the city could be moved a little. Thanks for checking though.
I probably already moved the city somewhat, given the relative size of the symbol on the enlarged bitmap version I used as the basis for this map. That linked version is the one I'm basing all my comments on now, however, as it's not going to change substantially before it hits the Atlas. Assuming I ever get the fortress mapping completed...
The way I've been thinking could influence parts of the city's final layout is all, drawing on the final notes write-up.
That's a great looking map. I love the way you have used the bevel to raise the henge on a mound
That will be the task of the creator of the city. Hint to Remy Monsen!
