Re-joining A Split/Broken Wall
Hey All,
Is it possible to re-join a split/broken wall? I'm mapping a second level of a set of gatehouse towers, and on the second level I want to join the walls back together in some places where they were split by having doors.
CMB) command to connect them. If they are filled polygons however it becomes a bit more complicated.Thanks all
Start a new map and save as filename01_001, do some work, save as filename01_002, etc. Most of my maps have fewer than 20 of these saved. Some over 100. Depends on how detailed and how often I save as.
That way if I decide to go back to an earlier version, I have it.
