Different shade on map
Hi, I'm trying to make a map. I'm using a grassland terrain. I tried to add a forest but made a mistake so deleted it with control-Z. After this, the grassland terrain now appears two different shades, and I can't work out how to undo this. I've tried refreshing, opening and closing the software, painting over it, but this doesn't work. When I paint over it, it reverts to the two-shades when I refresh.
Anyone know what I can do to fix this?
    The forest tool throws down both a background and the trees. This is a 2-step process as far as CC3+ is concerned, so you need to click Ctrl-Z twice in a row to properly undo.
    But the forest background can also just be deleted with the Erase image tool.
  • The Forest Tool creates a background polygon, oin which It then places the trees. Hitting Ctrl-z only undoes the läßt step. If you use the erase Tool an the shaded Arena ist will be gone. Or use Ctrl-z twice to undo both the trees and the polygon.
