Marriage Script - Mercator Revised (annual 11)
Hello,
First post on these forums. I've been learning to use Campaign Cartographer + recently and enjoy the styles offered by annual volume 11.
However, when I get to the Mercator Revised style, I have an issue with the text font "Marriage Script". The font that appears on my map is not the same as the one showed in the PDF example (see attached image)
Is this a problem other people also experience? Or am I doing something wrong? When I check the text properties it clearly shows it is written in "Marriage Script".
If anyone could help me, it would be much appreciated.
I don't remember if that font is supposed to be installed with that issue or not, but you can find it for free on the internet.
It's a font that is provided by the annual but not installed.
So if you search for Marriage Script on your system you should find it. When you do, just double click it and then hit the install button.
