Doors keep flipping
I'm pretty new to CC3, but having a go at my first dungeon. The 1st problem I'm having is that the doors keep flipping when adding them to walls. I rotate the door, as can be seen on the right, but as soon as I put it on the wall it flips, and I can't change it. Is this a feature, as it assumes that the outside of the door needs to be on the outside of the room.
Door.PNG 305.5K
    Doors will auto-align by default when you move the mouse over walls. There are two options if you need more manual control:
    1. Right-click the Snap button on the lower right of the screen, and uncheck "Cursor Snap". That will allow you to move the cursor just a little bit to either side of the wall, controlling which way the door will flip. The door will still snap to the wall, but in the chosen orientation.
    2. Right-click on the drawing area witht eh symbol at the cursor and check the "Disable smart symbols" option. That way the door will not auto-align or cut the wall, but will still use the snap grid (if enabled).
