Pete Fenlon Style Problem
Shessar
🖼️ 33 images Surveyor
I'm starting a new campaign and have decided to use the Pete Fenlon style for my regional maps, but have run into an annoying problem. When I create a new map, choosing to enter the dimensions myself, I enter 500W x 400H but end up with a map that is 460W x 360H. The map border is the correct size, but the background fill is too small.
Any idea of what I'm doing wrong? I'm so used to starting from a blank template and doing my own thing that I'm not sure if I'm using the wizard correctly.
So yeah, weird.
Edit: For some reason I can't get attachments to show up today...
Edit 2: Never mind - it was my fault because the image dimensions were too wide.
I've attached a version of the template, that will give you 1000x800 miles in the visible area by default. Hope that helps.
The Fenlon style looks best at smaller size local areas (using one of the two sheet effect settings - Fenlon Style or Fenlon Style Small), but that's a good template to dissect (Info -> List is the CC3 user's best friend) to make "custom" sizes.
Speaking of Fenlon Style and Fenlon Style Small settings, could you recommend "cut off" dimensions of when you should choose one style over the other?
What I'd actually do though is go through the effects and adjust them to my map. It's fairly simple, just multiply any size-related effect values (that's mostly blurs, glows, edge fades and shadows) by a factor that equals your maps relation to the standard template (e.g. if your maps is 200 miles wide, that's a factor of 0.2).
