How to import annuals in CC3+ OR Change Existing Canvas size?
FarsightX3
Traveler
Hi guys. I was wondering, how you would import old annuals into a new CC3+ file?
Also, is there a way to resize an existing canvas? The old SCALEXY > Select All > Modify "X" > Modify "Y"in command line doesn't work for me anymore.
Any ideas?
Thanks!
Any ideas?
Thanks!
If you only want to resize the canvas, use File -> Resize Drawing Area. There is no reason why SCALEXY should have stopped working though, that command should work the same way as it has always done, but that procedure will resize the entire map, not just the canvas.
As for fills, the procedure is the same as you describe, use Draw -> Insert file to insert a drawing from another style (but with the drawing on the cursor, just hit Esc instead of actually placing it), that will copy the fill style definitions to the map, and you should find them in the fill style dialog. You should also be able to use the drawing tools from that style as well.
Nothing has really changed for these things, they should work as they have always done.
See screen shot below.
There is also a possibility that the scaled setting for that particular fill was changed to a very high value, you can check that from the fill style dialog.
