How can I fill a polygon created with the line tool?
I am working on a map for my d&d game. It consists of a peninsula surrounded by sea on three sides. I am new to the program and still have quite a bit to learn, but for now I have a pressing question.
The peninsula I have created is on it's own sheet called CITY BORDER. I made the mistake of creating it with the line tool. I have come up with a shape I really like, and do not want to have to recreate it with the polygon tool. However, I can not seem to figure out how to fill the interior of the shape without doing so. All of the lines I used have been grouped to make one flowing border, and fractalised to look natural. As I stated above, I am quite new to CC3, and so this process took me some length of time to get it just right. I would hate to have to scrap all of my work and start over, so if anyone can offer a bit of insight, I would be extremely grateful. I have searched the forums, and can not seem to find any topics that cover this particular issue. Thanks in advance.
-Ben
-Ben
Then it depends on what you have done with the lines. Lines made by the line tool cannot be fractalized, so I assume you have already made them into a path. If you haven't, you need to use Line to Path [LTP2] on them to convert your individual line segments to a Path. (Convert all of them to a path in one go, this makes a continuous path)
If you converted each line to an individual path when you fractalized (Meaning your coastline now consists of many individual entities instead of a long path), you need to use Combine Path [CMB] to merge them into one continous path
Finally, use Path to Poly [CLOSEPATH] on the now combined coastline. It will turn into a closed polygon. Now you can use change properties on it to set the appropriate fill styles and so on.
All of the commands I mentioned above can be found by right-clicking on the Fractalize button (Or the Explode button).
Step 2 (Combine Path) is only required if your entire coastline is NOT selected when you select part of it. If you can select the whole coastline in one step, you can skip this step as well.
Your lesson has led me to wonder, however. What greater purpose do paths serve in CC3? What is their primary function, and how do they integrate with the other tools? (Feel free to let someone else field this if you don't care to. You've already helped me quite considerably.)
Turning lines to path has many uses :
i) only a path may be turned to a closed polygon (in fact, in memory, path and polygon are almost the same)
ii) it saves memory (each line is recorded as two points whereas in a path each point only occurs once)
iii) easier to edit (for the same reason, if you keep connecting lines and want to move a point, you must move it on both lines, if you want to change the color, you must change each line...)
I'm getting there.
