problems accessing Dundjinni's forums
HelenAA
🖼️ 5 images Surveyor
Is anyone else having problems accessing Dundjinni's forums and search fascility?
Every time I try accessing the pages time-out and I'm left looking at a blank page with some (to me) meaninglesss message, viz
It's even more frustrating when I get to the search results page and it tells me the number of results and THEN I get the error message above
Microsoft OLE DB Provider for SQL Server error '80004005'
[DBNETLIB][ConnectionOpen (Connect()).]SQL Server does not exist or access denied.
/forums/search.asp, line 431
Generally, if you reload the page enough times, it will work, but it can really try your patience. Not that a bunch of people continuously reloading the pages helps in any way though, it probably makes the problem worse.
