Glitch
Glitch
Glitch
1,592
Member
808
Surveyor
  • [WIP] The Wizard of Schley
    Yes! Starting at the top level at each lower level you slightly increase the symbol size, while reducing the overall map size --so they see less outdoor space. I used this to add a teaser on the next game - a burning house could be seen in the distance from the top level.
    Royal ScribeDon Anderson Jr.
    Awhile back when I tried my hand on a tower, I created a base file that I used to ensure that all the exterior layouts matched. I started with the top floor of the tower; for the next floor down, I slightly shrank the file size and adjusted the overall transparency to make the ground slightly clearer. Repeated this process to the ground level where the transparency was totally removed. My attempt at conveying the broadened horizon you get as you move higher in a structure.
    I cant find the images anymore.....but the players complimented it at the time.
  • WIP - Wayward Village and Inn
    Thanks - How's this look:
    Don Anderson Jr.QuentenKertDawgRoyal ScribeLoopysueRyan ThomasDaniel Pereda De PabloJuanpiGabriela
