Glitch
Glitch
- Glitch
- 1,592
- Member
- 808
- Surveyor
- 6
Reactions
[WIP] The Wizard of Schley
Awhile back when I tried my hand on a tower, I created a base file that I used to ensure that all the exterior layouts matched. I started with the top floor of the tower; for the next floor down, I slightly shrank the file size and adjusted the overall transparency to make the ground slightly clearer. Repeated this process to the ground level where the transparency was totally removed. My attempt at conveying the broadened horizon you get as you move higher in a structure.
I cant find the images anymore.....but the players complimented it at the time.
WIP - Wayward Village and Inn
