Glitch
Glitch
- Glitch
- 1,592
- Member
- 808
- Surveyor
- 6
Reactions
WIP - Wayward Village and Inn
1. Used Color Key on Grid. What a wonderful solution – I had been playing around trying to find a way. As soon as it was mentioned, I slapped my forehead and shouted “Duh”.
2. Moved “Balcony” floor to its own layer, adjusted stairways
3. Aligned Text sections.
4. Enlarged base drawing – thanks, again a great suggestion
I use the hex grid since it is intended to be a battle map, and it displays well on our home made tabletop.
Tomorrow is a travel day, so no more work until Sunday. As always - any comments or suggestions are welcome!!!
Wayward Casino
Located in the front of the Wayward Inn, the Casino is run by Dapper Dan and order is maintained by Sweetie (Lead Bouncer) and her crew.
The doors behind the bar lead to the kitchen, beyond that is the Inn’s main dinning room. There are no windows and the only public entrance is the foyer off the street. On either side of the Common Casino are a set of stairs leading to a balcony and the “Rent by Hour” rooms. The Common Casino also has a small stage – currently playing are “Bletcher” Smites (Various Instruments) and Uvaldi (Singer).
The Casino takes 15% of each pot and charges table fees that range from a few coppers to 5 gold pieces. Games include: Poker, Cheater’s Poker, Whist, Roulette, Various Dice. There is also “Barrel Riding” contests where two opponents face each other standing on the barrel and exchange slaps.
The Casino is usually well attended with weekends being extremely busy.
