Glitch
Glitch
- Glitch
- 1,592
- Member
- 808
- Surveyor
- 6
Reactions
WIP - Bend Road Crossing
Darklands fits perfectly in my current scenario - a Druid ruled land where the Druids are draining the power from the land. Need to clean up and add text labels to building. (Brewery, Tavern, Inn, Stables, and Slaves quarters.) Not sure what the ruins on the north side of the river represent yet.
Comments and suggestions appreciated.
New Oxtail - WIP
Set aside the mountain presentation to finish the city layout. As a struggling user, I learned allot of the basics - move to sheet, change properties, basic edits, also played with different sheets and effects. Struggling with color, current approach is to color by zones - with buildings/areas that are documented showing color. Going to go back to playing with the mountain presentation.
New Oxtail - WIP
Tried Shessar's PDF tutorials - it works well for battlemaps (I used the technique on Fanche Pass, but had forgotten about it), but I couldn't get anything I was happy with. Ended up playing with sheets and effects to settle on the results below. Needs more clean up (cliff base rubble showing through and coast needs cleanup, but the concept is there. Thanks for the help.
Fanche Pass Campsite - Battlemap
New Oxtail - WIP
First try this morning - used a combination of the approaches suggested. Used Sue's bevel technique, then added color polys below to try and add interest (added the green garden fill for the base, and then "painted" the tops using the crushed stone fill). Improvement, but needs more work - clean up around the ocean base. Will try the Shessar's PDF tutorials tomorrow morning.
