Fersus
Fersus
Fersus
906
Member
247
Surveyor
4
  • herbalists home
    just wanted to bash together a "quick" battle map with the woodcutter style.
    took me about 3x as long as it does Ralf, but let's not talk about that ^^
    here is the top down view:
    and this view let's you peek under the roofs (of the hut and of the trees ^^):
    As always: any suggestions/remarks are always welcomed!
    Monsenroflo1LoopysueWyvernEukalyptusNowRicko
  • [WIP] Custom Map for Dune Boardgame
    Update on the Dune Map:
    The bad news is: I hadn't had the time to extract all of the tiles myself :/
    the very good news is: the stranger who made the dune 2000 board contacted me and asked if I'm still interested in the map.
    I said yes and he said: that's great, because I'm not interested in this project anymore. Take it!
    And he sent me ALL OF HIS ORIGINAL FILES!
    I was totally blown away!
    Now the extraction of the tiles is still annoying but I only have to do it for additional assets (buildings and units or minor corrections of the original map)
    Here's what I got so far:
    Details:
    I think the text has too much outline and I'm not sure if the borders are too much/too little or just right (that will be determined by a testprint)
    I used the spice silos as "settlement" buildings, but I think they don't quite fit- Mostly because of the bright ring on the base, which is in the original image. I either edit this or remove them completely. haven't decided yet.
    As stated above: the bulk of the work was done by the kind stranger. I added the borders, the buildings, the text and the spice fields. The original spice fields where not vivid enough, so I added an orange smooth poly with a strong edge fade effect, setting the other border to just 1% in the inner opacity to 25%. That gave the orange spice fields just enough orange glow to make them pop more, without giving away the effect like the borders do.
    In the full picture you see the background rotated slightly. Everything outside of the black Ring is not part of the planet anymore and I'd like to add some Space background. There will be fields for gamephases, Round counter, Bank and the tlailaxu tanks, so it's not that important what I use exactly, but it should look nice anyways.
    Any suggestions? I do have the cosmographer addon, but I've never installed it so far as I've never needed a space map before...
    JimPGlitchDon Anderson Jr.Wyvern
  • A Teleport Hub
    I played around with Lillhans' suggestion of layering different sheets that get darker and darker, but I was not happy with the result.
    After hours of trying it hit me: why don't I try to superimpose a lighted bevel on my cave fill? The cave wall fill was to dark for that, but after choosing a brighter one, it looked quite nice:
    But now for the boss level: The fade to wight... ahem... fade to white of course ^^
    AS implied in my first version, I'd like to save ink by not printing the negative space behind the cave wall. So I added a layer to the bottom of the list with a strong edge fade effect. The Idea being, that the plateau where my view cuts into the cave walls will be white and the edge fade makes the cave walls brighter the "higher" the elevation is. Just as the traps indicate depth by getting darker, the edge fade should indicate height by getting brighter.
    This looks okay-ish where it works, but unfortunately it leads to a lot of acne:
    and it's even worse on printing:
    "ok" I thought. "This is surely this $?§!%&! effect again where effects don't work properly when the color underneath is the same. I know how to handle this: just add a layer in a different color just beneath the fade-to-white Sheet (well: on top of it in the sheet list), then the effect should vanish. It feels like quite the roundabout way of solving it, but it should solve the problem, so let's go!"
    Well, it didn't:
    It did improve the situation quite a bit, as this is the printed version again. So when we are sufficient far away from any edge where the fade effect could be triggered, we indeed get a completely white area. But on the edges the acne still appears revealing even the black polygons that I hoped would fix this problem.
    Does anyone know what's the proper way of handling this?
    RickoLoopysueLillhans
  • Fast Marshes Tutorial
    reading your tutorials be like:
    Steps 1 - 6: ok, ok, pretty chill so far
    Step 7: and then the doom music kicks in :D
    Ricko
  • A Teleport Hub
    This is supposed to be a hidden cave that elves used to install 8 teleport portals for a guerilla war against the invading humans. But this was a very long time ago, the elves lost by now and some baddies stumbled upon this and used it for their nefarious purposes. Now our heroes found out about this, and it's time to take out the raiders camp behind the 8 teleporters one at a time.
    One of the natural paths will be blocked by a cave in (there'll be a secret behind it, thats even older then the elven wars. Maybe that's why none of this looks like elven work? ^^).
    The hub is designed in a way, that if one elven warcamp should fall and enemies are using the teleporter to enter the hub, the defender on the central platform can shoot the intruders one at a time, while the enemy has to walk through the portal first to even get a glance at the defenders.
    I'll add some drawbridges and decorations later, for now I wanted to showcase the bottomless pits. I really like how they turned out 🤩
    The best thing about them is that this is just a black polygon with the edge fade effect and some lines added to emphasis the contours. The "cracks" symbols from the CSUAC Symbol set where used A LOT here, as they really made it easy to get the result that I was aiming for.
    I ended up using them even for the floor that's not near a pit, just because they are a really nice touchup for the bitmap fill...
    I'd like to get a similar 3D effect with the cave walls, but I don't really know how. Any suggestions are highly appreciated 😀
    LillhansLoopysueRickoLautiLizzy_MaracujaAleD
