Calibre
Calibre
Calibre
1,367
Member
965
Mapmaker
8
  • Melniboné
    I luv it. Brings back so many memories, Dak. Thanks!
    Cal
    JulianDracos
  • Fantasy B&W Map
    I like the B&W version better meself
    Cal
    JulianDracos
  • WIP: The Citadel
    Ok, did a little work on the conical tower tops. I've noticed trying to do non-visual rotate, that the rotation spins counter-clockwise. Might be my eyes, but I tested it vigorously heh. Correct me if I'm wrong, please.
    I added light to the tower tops and used an edge fade. May need to tweak that a bit more...
    Cal
    Also, the drop shadow under the windship/skyship is there mainly for my players to clearly see it's floating; but I don't like that. I need to either displace it more and/or lighten. Not sure yet.
    Cal
    LoopysueAleD
  • WIP: The Citadel
    Well, in an effort to show the sheer scale and scope of 'The Citadel' on Mor Stonisch, I present this WIP.
    There's a lot that needs tweaking and I'll accept any and all advice!
    Not labels, yet but the logo and the scale are correct.
    thanks
    Cal
    MonsenLillhansGlitchRicko Hasche
  • My first completed map utilizing CC3+
    Well, I think you clearly understand CC3+. Map looks great and your work is only going to get better as you master the techniques mentioned above.
    Don't be afraid to import other styles into your map. Remy has detailed instructions all over the forums on how to do that.
    Learn Edge Fade as Wyvern suggests...man, this will really add so much.
    Use the drawing tools on the right, like Smooth Polygon, to make your own fills from wherever you get them: in program or imported.
    Learn to Love: Sort Symbols in Map 😁
    Learn to Love: Adding your own sheets and effects
    Learn to Love: Draw Symbols in Area
    CC3+ and other addons are very profound programs which can seem overwhelming at first, but with a little patience and determination, you'll master it.
    Cal
    OwlishlyTabooRicko Hasche
