Calibre
Calibre
Calibre
1,492
Member
1,086
Mapmaker
  • Difference between layers and sheets
    Hey all!
    Sheets separate various effects. Use them to separate effects. For example, say you want a blur on specific fill, or a colorize, or a blend or whatever: Make as many sheets are you feel you need, partitioning off effects.
    Layers organize the specific elements of your drawing: like mountains on one layer, reliefs on another, rivers on another etc and so on. Forests go on Vegetation.
    Doing this, you can manipulate your maps as you see fit. Use both to your advantage. Always check which aspects of your drawing are on which sheet or layer. Choose which one goes to each.
    Cal
    Royal Scribe
  • Watabou City REVISED (annual 157)
    Mr. Quenten, thanks for the hard work. I feel confident it will be awesome
    Cal
    Quenten
  • WIP: Nirmathas on Golarion
    Greets!
    I do not know if the following information is wanted; but I will reveal how I did this map.
    First: I opened the map in Darklands overland. I inserted Spectrum Overland and Watabou Cities. These provided me with the Fills I knew I would need.
    Then, draw your Land.
    Then, once I had the Land to my liking, I went to the drawing tools on the right side of the screen, chose the various tools there to draw blobs of various colors. I put these on individual sheets, each color to a specific sheet. Now, add effects: blur, blend and edge fade till they 'look right to you'. WARNING: this will slow down everything. Turn off effects to help you draw out what you need.
    Again: turn off effects to draw what you need. ๐Ÿ˜
    I draw what I know what I need or want. Sometimes, it takes many times to draw 'what looks right'. I can't describe this process any clearer than to say this: think outside the box.
    Think outside the box.
    Cal
    PS: I hasten to add: You can do this with any style you have in CC3+. You don't have to have the ones I have listed here.
    Royal ScribeQuentenRickoGlitch
  • Tutorial - Between hills, rivers and trees
    Greets!
    Great info, Ricko!
    For the river attaching to the coast, I have 2 other ways of 'getting it right' ๐Ÿ˜
    1: Use the Node Edit tool on the left; grab the node of the river closest to the coast and manipulate it so that the river aligns as you wish to the coast.
    2: Edit>Reshape>Stretch: to pull the end of the river to the desired location.
    You could, also, BREAK the river further up from the river end, then STRETCH it to the coast as you desire. Or, BREAK it and redraw the portion that is not aligning, making sure to use F5 to attach the new river line and then F9 to ON it to the coast again.
    Cal
    RickoRoyal ScribeJuanpi
  • What I've been working on
    Greets, Ralf
    Here is one:
    Ralf
