9,992
Member, ProFantasy
9,867
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Another little battle map
    Another map showing a nicely blended mix of styles - well mapped :)
    EdE
  • [WIP] The Sewers of Elmsbrook Township
    Very inventive, and a nice use of combined styles :)
    Royal Scribe
  • Spider Attack!
    Thank you :)
    Ricko
  • Assistance with Map Overview Export
    I agree with Kertis
    These are the settings I use to export the largest of my example maps as JPG files. The file size resulting is usually around 5.7MB and visually no different to a png file.
    Notice the Antialias setting, and also keep tabs on the "work size" shown lower right. More antialias is a smoother result, but it also increases the work size. Try to keep that no larger than 10,000 x 10,000.
    Incidentally, with this setup you can export the map as JPG without having to use the rectangular section options. The export will be automatically trimmed to the map border so that the longest side is 5000 pixels. These settings also do away with the white space around the map.
    Royal ScribeSkidAce
  • Is CA46 Castle Walls still state-of-the-art?
    Yes, all the annuals work with CC3+ because they were updated to do so. (If you should find an exception to this rule please contact Tech Support).
    Unless there is a style of a similar name with the additional word 'revisited' included, then the one you have is likely to be the most up to date version of that style (or toolset). To the best of my knowledge there isn't a 'revisited' version of that issue.
    Royal ScribeJimProflo1
