9,991
Member, ProFantasy
9,866
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • [WIP] Community Atlas - Eknapata Desert
    Better again.
    The thing about sheet effects is they do take a lot of tweaking to achieve perfection, so you may wake up tomorrow morning and take one look at it and decide to change it again.
    I don't think it's too much, but it may still be on the borderline of too little. Small adjustments are better than large ones till you hit the sweet spot between not enough and glaring. And then there will always be issues with subtle but efficient text glows where some may still not be able to see it even though you can.
    Royal Scribe
    That's better. The labels are no longer screaming out of the map like before, but I think you may need to increase the opacity or the extent of that one glow. There's at least one label I can't easily read - the temple of Fah. I might not have adjusted it to perfection, but only enough to show you how little you could sometimes get away with.
    Royal Scribe
  • Annual Darklands fill question
    I did a quick sampler of all the forest and woodland drawing tools with the tool names shown for identification.
    The trees from Darklands are quite dark compared to other styles, so you won't get any lighter trees than the jungle ones.
    I think you might have the blurred FOREST SHADOWS sheet above the FOREST* sheets (above in the map - below in the list). That would cause the blurring seen in your shot. Check to make sure the sheets are in the right order.
    As for the drawing tools themselves, the forest ones all seem to be in order, but the last two woodlands drawing tools seem to have a higher than expected density. I don't know if this is intended or not.
    jslaytonRickoCalibre
  • Live Mapping: A Not-So-Peaceful Village 2
    Hi Everyone :)
    In this week's live mapping session Ralf will continue working on his village map for the Community Atlas Project and its 1000-maps celebration.
    Come and join in the chat with the live session on YouTube here:
    https://www.youtube.com/watch?v=PBzOFXIk1Wk
    Or you can watch it here later if you wish:
    Date and time shown in the side bar of the forum, or on YouTube if you follow the link.
    QuentenRoyal Scribe
  • Photo Hex Map W.I.P
    That's an interesting idea.
    Looks like you've got a lot of stuff sorted out already.
    C.C. Charron
