- Loopysue
- 9,976
- Member, ProFantasy
- 9,857
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Birdseye Continental - style development thread
Live Mapping: Mike Schley Regional
This week in live mapping, Ralf will be creating a regional adventuring map using the the Mike Schley overland style. Come along and join in the chat live on Youtube: https://www.youtube.com/watch?v=Aq2Vh5oz05Q
Or watch it right here if you prefer*
*There's no live chat on the forum.
All the live mapping sessions are recorded and available on the Profantasy Youtube channel.
Vignette in CC3
Another way of doing something similar (if you want a rectangular vignette, for example), is to cover the entire map in a polygon and use an EFI turned inside out (100% opacity on the outside, and zero opacity on the inside), then a Blend Mode to control opacity and how the vignette works with the map.
Question about CA143 Asian Town "well" symbol
@ScottA - Oh that was a ring of mapped symbols. I was checking the map file worked from all angles and made a circular array of the same mountain ridge symbol. The symbols do some pretty experimental things as far as having fades all around, which is never done in a house symbol, and sometimes do unexpected things. I will have to check each and every mapped symbol the same way so you don't get any weird effects just by rotating one a little bit.
I will make a crater symbol.
@Don Anderson Jr. - Unless you count tundra as a kind of desert itself? How is a desert defined? Extreme dry? Extreme heat/cold? Anywhere the plants and animals have a hard time?
