9,966
Member, ProFantasy
9,852
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Voucher Codes
    Hello chongjasmine :)
    This is quite an old thread, so the information is no longer entirely correct. These days Profantasy have taken to doing the occasional Humble Bundle. You happen to be in luck, because there is a bundle you could have if you wished right now - here:
    Profantasy Humble Bundle - 2020
    (I suspect this link will not work after the bundle is over)
    But there are now only 3 days left to get it as I type this comment, so I hope you read it before it's too late to choose.
    ZaRue
  • old and new Barrow Isles, using Project Spectrum
    Coming soon - in part 2 ;)
  • Seven Kingdoms map updated
    That's how we normally do it around here - new WIP, new comment, so there's a story to the whole thing.
    It's better than constantly replacing the initial image, which has the disconcerting effect of making the comments underneath it make no sense at all.
    DaishoChikara
  • Drawing tool macros
    Ok. Different project entirely...
    If I had a tool that drew a poly on one sheet, but I wanted that poly copied onto no less than 5 other sheets simultaneously, would this be possible using a macro?
    The reason I ask is because I have this idea for a new style that depends very much on being able to easily draw a land-shaped hole through 5 sheets of ocean without getting into all the complexities of copying it across one sheet at a time by hand.
    This is the map so far - a doodle just to get the effects heading in the right direction. The land shades are all in the background. That's how I've got them to behave in a way that doesn't depend on the coastline. But to do this with drawing tools I would need a macro that put the same Colour Key shape on all 5 ocean sheets at the same time.
    kilma.ard.venom
  • The Land
    Wow!
    Maybe he missed his true vocation? People pay for plans like these.
    (And now I'm wondering if your hubby could be persuaded to learn how to create a few new CC3 styles!)
    deromilly
