- Loopysue
- 9,966
- Member, ProFantasy
- 9,852
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Voucher Codes
Hello chongjasmine
This is quite an old thread, so the information is no longer entirely correct. These days Profantasy have taken to doing the occasional Humble Bundle. You happen to be in luck, because there is a bundle you could have if you wished right now - here:
Profantasy Humble Bundle - 2020
(I suspect this link will not work after the bundle is over)
But there are now only 3 days left to get it as I type this comment, so I hope you read it before it's too late to choose. -
old and new Barrow Isles, using Project Spectrum
Seven Kingdoms map updated
Drawing tool macros
Ok. Different project entirely...
If I had a tool that drew a poly on one sheet, but I wanted that poly copied onto no less than 5 other sheets simultaneously, would this be possible using a macro?
The reason I ask is because I have this idea for a new style that depends very much on being able to easily draw a land-shaped hole through 5 sheets of ocean without getting into all the complexities of copying it across one sheet at a time by hand.
This is the map so far - a doodle just to get the effects heading in the right direction. The land shades are all in the background. That's how I've got them to behave in a way that doesn't depend on the coastline. But to do this with drawing tools I would need a macro that put the same Colour Key shape on all 5 ocean sheets at the same time. -
The Land
