- Loopysue
- 9,967
- Member, ProFantasy
- 9,852
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Physical Manual and Essentials Guides
Unfortunately, owing to cost of production combined with the tendency for such things to be regularly updated and render physical copies out of date in a matter of months, I don't think PF do printed copies any more (though I might be wrong).
The only thing to do if you really must read on paper is to print these things out yourself. But be aware that updates are not done on nice convenient update sheets. Things are just generally updated, so eventually you will have to print the whole thing out again.
Project Spectrum - Part 2
Fill styles arent being selected automatically. Bitmap has to be added manually. How do I fix this?
You have the Jon Roberts drawing tools, but the fills I can see in your map and the symbols are DD3. These are different styles.
While it is perfectly fine to mix styles there are a few issues you might encounter along the way. To solve the most likely ones...
- If you don't have the right drawing tools for the style open the drawing tool dialog and where it says CD3 Floorplan DD3 in the dropbox at the top in your last screen shot there, click the down arrow and pick the right style.
- If you don't have the right fills for the style you want to use, create a dummy file of the desired style and use Import file in the Draw menu to import the dummy file into your current map, but abort the operation just before you paste the temporary file into the one you are working on. This will import the bitmap fills into your map without pasting any other irrelevant stuff.
- If you don't have the right symbols you can navigate to the right symbol catalogue using the folder button at the top of the symbol catalogue pane. Be careful to open the catalogue file and not the actual folder containing the symbols. Catalogue files are .FSC files.
I hope that helps ?
Seeking advice/tips re: world mapping with FT3/Wilbur
You're welcome (you mentioned The One Day Worldbuilder there) ?
I think with a project like this you need to take it one stage at a time rather than trying to think of everything all at the same time. Just note the major geographical features you will need at roughly what latitudes, then draw a simple scribble map of the land shapes, either by hand or on PC it doesn't matter (though if you do it in Paint or GIMP you can import it to FT3 as an image overlay and use it as a pattern to sculpt on).
The thing about really massive projects is that they seem to be totally daunting if you don't break them down into more manageable chunks. I do understand what you are facing. I've already made well over 100 new symbols for part 2 of an overland style, and there are nearly as many to do yet. I could easily sit here in a state of despair and get nothing done at all, but instead I just blinker myself to the overall picture and say to myself "Today, I will get those 3 swamp trees done," and I do them.
Train yourself to think in little chunks. No one can fit an entire world into their head at the same time.
