9,966
Member, ProFantasy
9,852
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Gamma Dawn Compound - First maps using CC3+
    Fascinating! I really like the night time version :)
    I hope your GM appreciates all the effort you have put into getting it done.
    argel1200
  • Project Spectrum - Part 2
    Sorry, Quenten.
    I really don't have time to do more than has already been agreed with Profantasy. I'm pushing it even now because I've had a series of stupid delays at my end of things - like taking 2 days to find out why just one kind of tree simply would not render correctly.
    I don't think there will be a part 3, which is why I'm being really definite about not doing anything beyond the spec until the spec has been fulfilled.
    JimP[Deleted User]
  • PNG Export sometimes duplicates a couple lines?
    Oh, I see it now. And its something I remember mentioning a very very long time ago when I was trying to get a rendered map that was about 10,000 px square done - only I didn't realise it was actually a repeated line. I just called it an 'artefact', I think.
    I don't know how you stop it, but the thing that helped me back then quite a lot was increasing the depth of the passes CC3 does as it scans across the map from side to side during rendering. There are fewer of these artefacts then, and if you are lucky and don't go too massive you can do the whole map in a single pass.
    EXPORTSETMPPP asks for and adjusts the Maximum Pixels Per Pass. Type it on your keyboard and hit Enter. Check the Command Line Prompt. It will tell you 4000000 (4 million). Type 40000000 (40 million), and hit Enter, then try rendering again.
    argel1200
  • Way to copy effects?
    The Copy and Paste buttons to the right of the effects panel, below the Add Edit and Delete buttons, will copy whichever effect(s) you have highlighted at the time, and then paste them in whichever sheet you have active.
    The copy button is only active when you have at least one effect selected, and the paste button is only active once you have copied something.
    You can also copy and paste effects between sheets in different maps as long as they are open side by side. (I've never tried it by closing the first one and opening the second one).
    argel1200
  • Physical Manual and Essentials Guides
    And here is another perfect example of how Remy and I quite often 'ninja' each other in responding to questions ?
    JoeyD473JimPPunch
