9,968
Member, ProFantasy
9,852
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Project Spectrum - Part 2
    Speaking of structures, I totally forgot the trade ship. I've lived all my life on the coast and even sailed across the Channel on a couple of occasions, but I haven't ever managed to get the curves of a boat right in a drawing. So here I am using original ship plans from this site http://www.shipmodell.com/index_files/0PLAN1A.html#5S (its just a bit tricky downloading them, which is why I haven't suggested it as a general resource) to construct the crude shape of a Portuguese carrack "Nau del Cantabrico XIII". It's a medieval trade ship with one square sail. Something nice and easy to start with. That was the thinking behind my choice anyway - that and the fact it has one simple squarish sail that will make it instantly identifiable as a ship, rather than an exotic squashed insect with white wings.
    A bit much for just one vessel in an overland annual style? Maybe, but I can easily build up a set of these things now I've worked out how to do it and potentially make a whole fleet of them over the years.
    And don't worry! I have no intention of making anything more than a simple outline with the deck and mast so that I can use it to guide a hand painted version. Much faster!
    As for why I didn't just google "Isometric sailing ships" - I did. There wasn't a single one I could use.
    [Deleted User]RaikoMonsenJimPkristof65
    If we were all artists nothing would ever get done. We might imagine things...
    Leonardo da Vinci's second flying machine drawing - 1485
    But we can't design the reality and build them like the mathematicians, engineers and scientists can.
    Igor Sikorsky with his working helicopter -1933
    So this modern world we know only exists because we all have different talents - none of which would have been much good without all the others.
    MonsenDaltonSpenceRaiko
    Aw, Quenten!
    There really is nothing to it, though. You just draw raggedy white lines down where you think the water would fall (usually in the cracks in the rockface), then take the blurring tool and work little circles of blur into it where you think there would be spray.
    This is the fall so zoomed in it's pixelated. As you can see its just a white scribble that's been blurred in a few places. Most blurring tools end up creating linear marks at this tiny scale, which you can use to your advantage with a waterfall - note the linear marks in the falls where I have moved the blurring tool fractionally from side to side.
    Then you come back with a nice sharp eraser and take out the white where the rockface protrudes in front of where the water is falling. Not all of it. Just some very prominent bits of rock. And then you are done.
    This is the fall on its own - showing how simple it really is. You've just got to be a bit patient with yourself and think about the shape of things as you work. Be the water falling down that cliff. Well... not literally, but in your mind, of course.
    The other big 'secret' is to use your background.
    If you've taken all that time and trouble to create a nice cliff to put this thing on, allow some of it to show through. Don't just cover it with a massive sheet of water. Most falls are more modest than Niagra, which is an impressive but artistically rather plain looking extreme of the phenomena in my opinion. Smaller more jagged falls that bounce around in the crevices are much more interesting to study.
    So where the blurring ends up making the white bit you drew go transparent, don't fret. Just use it. It's like one of Bob Ross's happy little accidents.
    Oh, and don't forget that it all goes crash at the bottom if it didn't higher up, so you can go a bit wild with the blur tool down there.
    The optional extra is a layer behind the white of the waterfall set to "Glow and 50% opacity (in this case) just to paint and blur a few dabs of black to make the rock around the fall look wet. Be careful with that, though, it can really overcook things and make the whole thing look wrong. The other two falls in the set don't have this layer.
    To complete the set here is the cliff before the waterfall is drawn. Maybe you can extract from these images whatever I've forgotten to say?
    I just happened to chose the two cracks in the rockface that I did. I could just as easily have chosen another two, or done several/all of them. You could open a copy of any of the VH cliff symbols and practice in GIMP (though I recommend something with a much better blurring tool than GIMP, like Affinity Photo as above)
    MonsenRaikoWyvernJimP
  • Having a lot of difficulty selecting a single entity on my map
    You know, Raiko, you're absolutely right. SHIFT doesn't do anything in particular. I just hold it down anyway because I do it with Blender when I'm selecting all the models I've made to move them around.
    I blame using too many different apps with too many different shortcuts.
    Sorry falterego. Ignore what I said about SHIFT. But the CTRL keyboard shortcut is definitely a thing.
    Raiko
    Thank you - though the falls were by far the easiest part. They are just white scribbles done in AP on top of the finished cliff image, and took me about 5 minutes to do right at the end.
    With me I think the last one for tonight is about a certain anxiety that it might actually be rubbish and I was just wishful thinking it into perfection. It has the same feeling of mild panic attached to it as suddenly realising half way around the supermarket that I might not have properly locked the front door on my flat, or sometimes I think I might have left my car lights on :P
    With time quite short now for getting things done for November's issue (they have to be on Ralf's desk by mid October so that he can do all the technical stuff that to my relatively non-technical mind appears to be magic), I think the lava flows and falls will have to wait until the next time.
    RaikoJimPkristof65
