- Loopysue
- 9,969
- Member, ProFantasy
- 9,853
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
FT3: Removing an inland sea?
Since I am not an expert by any means, and know even less about brushes other than the prescale offset brushes, I think that unless you have several backups saved that you might be able to work forward from again, you might need help from someone like jslayton (Joseph Slayton), or one of the other more seasoned FT3 users.
If this is a world you have re-imported back from Wilbur, having done something like CA155 to it, the only recommendation I can make that might help is to go back to the pre-Wilbur FT3 world and raise the lake using the prescale offset brushes at that stage and take it through the process again without the lake from the beginning.
At any rate, I recommend avoiding the tools that increase or decrease roughness. They are pretty difficult to control and can cause more problems than they solve unless you have an extremely light touch.
Kevin Morris aka Gothic03
Mike Patterson (Maidhc O Casain)
