- Loopysue
- 9,966
- Member, ProFantasy
- 9,852
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Dungeon Level Symbols
Live Mapping: Shessar's Cartouches
This week in Live Mapping, Ralf will be presenting the latest Cartographer's Annual issue (September 2025: Shessar's Cartouches) and demonstrating how to incorporate these beautiful new symbols into existing maps and styles.
Come along and join the chat with us live on youtube here:
https://www.youtube.com/watch?v=mxr5kPlCIA0
Or watch it later, either here or on Youtube.
This thread is not monitored during the show, but if you miss it you can ask questions and make comments below.
Creating Symbol Catalogs for New Style
I'm a little confused here. You say you are using existing symbols, and yet you are creating new folders?
You only need new folders if you are creating brand new symbols. The symbols can be used where they are if they are existing ones.
The Symbol Manager is the tool used to create new symbol catalaogues. You can't do it without the Symbol Manager.
The fastest and easiest way to create a new catalogue from existing symbols is to create a new file using the New Drawing Wizard. Pick the Symbol Catalogs group and "Pick a pre-defined template".
Hit Next, and pick the most appropriate catalogue type, though most of the time the simple Blank Dungeon Catalog.FCT will do.
Having created your new catalogue drawing, hit the folder button at the top of the symbol pane and find the catalogue containing the symbols you want. In this case I have decided to open the Creepy Crypts All.FSC, though I only want some of the symbols.
I only want the fungi from this style, so I expand the fungi collections and click them one at a time as if to paste them (but don't paste them).
Once I've done that if I then open the symbol manager I can see that I have all the fungi symbols from Creepy Crypts in the drawing, but none of the rest of the Creepy Crypts symbols.
I can then open another catalogue from a different style and add symbols from there the same way, and build my own list of symbols in map, which will appear in the Symbol Manager.
Once I've finished adding the symbols I can then open the Symbol Manager again and select all the symbols in the Symbol Catalogue and use the Save as catalogue button at the top to make my new mixed style catalogue.
I recommend saving the catalogue in the parent folder of the basic style type. For instance, if I have a catalogue of mixed dungeon styles I would save it as "Mixed Dungeon SD.FSC" in the Dungeon folder.
Once the catalogue is saved you can discard the drawing you were using without saving it. You have the FSC you wanted, and if you need to add more you just open the FSC file.
It's a little confusing, I have to admit, but once you get your head wrapped around it not that difficult to make your own personalised catalogue files from existing symbols without creating dozens of new folders and duplicated symbols.
As for the next stage - attaching the new catalogue to a button - I once knew how to do this but for the life of me I can't remember the process. Maybe others can help with that.
Distance
Altitude colors
