- Loopysue
- 9,977
- Member, ProFantasy
- 9,857
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Where to look for the CA107 symbols
@Maidhc O Casain If you click the link above and download the file, then copy it into this folder to overwrite the existing file by the same name, then reopen CC3 - that will have the same effect as the installer.
@Symbols\Maps\Ancient Realms
Live Mapping: Multi-level dungeons
Edge Fade and SS4/5
The Lakes of Michigami (Jerry's Map) - WIP thread
I'm doing a lot of thinking about different things right now. First things first - you say you have to have everything planned out before you start a map. I'm the opposite way around. Very "Bob Ross". Things just happen in a map because they happen. I've put a cursed/sunken city in the middle of that humungous swamp area. It's just an idea. Maybe it helps - maybe it doesn't. You choose if it stays or goes away. Please let me know what to put there instead though if you want it gone.
The other thing I'm thinking about is scale. How big are you planning to export this map? This is the area I've been working on today between other jobs, extracted from a full export at 3000 px on the longest side. At this scale the structure symbols may be a bit small to do their proper job as symbols. 3000 px at 300 dpi is a print that is 10" in both directions when printed out. I think that's probably already too big for an A4 sheet.
I've been using a lot of artistic licence on the design. If that's not ok, please say.
