9,977
Member, ProFantasy
9,858
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Dungeon of Schley
    Thanks Calibre :)
    The cliffs were originally designed to go with the CD3 Bitmap A style, but I think the reason I did lines anyway regardless was because it is incredibly difficult drawing cliffs without any lines.
    The cliffs are part of this year's Cartographer's Annual here: The Cartographer's Annual 2020 (profantasy.com)
    Its an annual add-on that you can buy each year - 12-13 issues each year.
    JimPDaishoChikaraCalibre
  • Banners
    Are these long enough for everyone? :D
    And will a simple middle section connecting symbol bit work for you? The ends of these title bars are still manual, I'm afraid.
    [Deleted User]WeathermanSwedenTheschabiWyvernDaishoChikaraElflingAleD
  • Banners
    @DaltonSpence - I'm wondering if what you really mean is a three+ part symbol rather than a connecting symbol?
    I've modified the ribbon symbol shown above to be in 3 parts because it is well over 6000 px long and far too huge to be thrown around as a symbol - especially if there is more than one of them in a single map. Here it is with all 3 parts neatly aligned, and with the middle section dropped away so you can see how it works. You would have to use snap to align them and then group the 3 parts together so you could move and scale it. There will be different length middle sections to make the ribbon longer or shorter.
    The end pieces have to have a fade on them so that any mismatches between the texture of the ends and the texture of the middle section will be softened, but you will have to make sure that the overlap is complete for the effect to work.
    The question is - will this be too fiddly to use?
    [Deleted User]WeathermanSwedenElflingAleD
  • Banners
    I think this shape is better suited to ribbons?
    WeathermanSwedenDaishoChikaraRaiko
  • WIP Morwara (Erdan Worlds of Wonder style)
    Indeed :) I'm slowly coming to the conclusion that the built in shadows for my own banners might only serve to irritate.
    Something that someone else mentioned to me when I was all set to do loads of really outlandish shapes - bear in mind that text manipulation in CC3 isn't the same as if you were using PS, and that not everyone has the software to do any post processing. There are certain types of banner that would be pretty difficult to use. It was suggested that I stick mainly with straight ones, but I think I will throw in a couple of perfect arcs just for a bit of variety.
    After all - what is impossible today might not be tomorrow.
    Medio
