- Loopysue
- 9,978
- Member, ProFantasy
- 9,861
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
Cloud Cover
It's not generally done, but easy enough.
Add a CLOUD sheet above all but the TEXT sheets, and add a largish blur effect to it. Then either add circles of pale colours (not all white), and/or use the freehand drawing tool with a line width set above zero to scrawl on that sheet in similar off-white colours.
Here is the smoke from a chimney stack done using scribbles and a blur.
SciFi Outpost - the Files
Fractal Terrain 3 beginner
No sweat.
Most of what I just said is available in more easily digestible bit-size pieces in the help tool you can open from within FT3, so you can take your time to learn stuff.
Exporting smaller regions might help a bit, though I'm not sure if it will help as much as you want it to. Whatever resolution the export is set to is the one you will get, whether its a whole world, or just a small continent.
Banners
Banners
