- Loopysue
- 9,980
- Member, ProFantasy
- 9,863
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
        FINISHED: Morwara (Erdan Worlds of Wonder style)
        Distortion of Color Image Overlay
        [WIP] Community Atlas Competition: the fire of Lielt'ma
        Scaling TilesYes, you can scale the fill. I am assuming here that it is a bitmap texture fill you are using. Click the last mini window on the bar of them across the top of the app, where it will have something that starts with "FS:". This will open the Fill Style Properties dialog. Select the Bitmap Tiles tab, and then pick the texture you want to rescale from the dropdown box called "Fill Style Name" Once you have the fill picked, look down a bit and you will see 3 boxes that control the scale of the fill. Make sure the first box is checked, and adjust the scale of the fill in the width and height boxes next to it. Ok and see what you've got. In most styles the scale is in map units, or in feet/metres depending on which template the map is based on. If you only have one tile per 5 ft square and the scale is currently "20", and you want 4 tiles per square you would need to reduce both scales to "5"
