- Loopysue
- 9,980
- Member, ProFantasy
- 9,863
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
        How do you Add Cave Walls?
        Cannot figure out how I broke the sheet effects - they won't show up
        Lines Arcs Paths and Multipolies
        Cannot figure out how I broke the sheet effects - they won't show upYour effects aren't broken. They are just scaled really tiny - so tiny you can't even see them. I've just been through the whole set and discovered that you have them all set to Percent of Drawing Extents Width as the Effect Units. This means that whatever figure you had in the Edge Width box (these were also really tiny before I started on the map) is only that percentage of the map width. I've changed them all to Map Units and given them about 10 map units Edge Fade Inner. I've also moved that piece of scrubland fill to the TERRAIN DESERT sheet because it was on the same sheet as the grassland behind it. That was why it wouldn't edge fade. You will probably still need to adjust them all to suit your taste, but at least you are on the right track now. To edit a sheet effect you need to pick the sheet in the list on the left and then pick the effect you want to edit and click the Edit button on the right.
        Community Atlas - Elen Daelarion - Thrarasie Faire Cave, 14 & Western Hill Fort, 16
