9,980
Member, ProFantasy
9,863
Birthday
June 29, 1966
Dorset, England, UK
Real Name
Sue Daniel (aka 'Mouse')
27
  • Suggestions for a Map and Vintyri
    I agree on that point. 4 yr old eyes would see the pattern and be distracted by it. Also, you have improved the contrast between the background and the much more important foreground elements. That has made it a lot clearer than before.
    jmabbott
  • [WIP] Atlas Competition Entry - Coils of the Cold Coroner
    That's a great start, Autumn :)
    I love the idea.
    And I do hope your feet get better soon!
    Autumn Getty
  • Advice on Drawing Mines
    I am sorry to hear about your disappointment.
    If you are really regretting your purchase it is always worth asking Profantasy for a refund or an exchange for something else, but it is best to do this sooner rather than later.
    We might be able to resolve the issue you are having with it right here once we see what it is, but if you are seriously dissatisfied it would be better to contact Tech Support without delay and mention that you wish you hadn't made the purchase. You can do this through your account page.
    I would still like to see what the problem is, though, because I am naturally curious and would like to know if there are weaknesses in any given style that might need to be worked on.
    JulianDracos
  • How do you Add Cave Walls?
    Try using List from the Info menu on the walls you have. See whether it is described as a polygon or as a multipoly. If it is a multipoly you will need to :CC2EXPLODE: it first before things will work.
    If it is an ordinary polygon please can you upload the FCW file so we can have a look at it and see why it's not working?
    JulianDracos
    It may be that the new walls are not on the right sheet and layer. Hide all the sheets except the WALLS sheet.
    If the walls have vanished they are on the wrong sheet and you will need to locate them and use change properties to move them to the WALLS sheet.
    If the walls are visible then they are on the right sheet, but make sure they are also on the right layer by using change properties.
    Also, if the shape you converted to walls this way is a multipoly you will need to explode it just once. It's not possible to edit a multipoly.
    JulianDracos
