- Loopysue
- 9,982
- Member, ProFantasy
- 9,863
- June 29, 1966
- Dorset, England, UK
- Real Name
- Sue Daniel (aka 'Mouse')
- 27
        Suggestions for a Map and Vintyri
        [WIP] Atlas Competition Entry - Coils of the Cold Coroner
        Advice on Drawing MinesI am sorry to hear about your disappointment. If you are really regretting your purchase it is always worth asking Profantasy for a refund or an exchange for something else, but it is best to do this sooner rather than later. We might be able to resolve the issue you are having with it right here once we see what it is, but if you are seriously dissatisfied it would be better to contact Tech Support without delay and mention that you wish you hadn't made the purchase. You can do this through your account page. I would still like to see what the problem is, though, because I am naturally curious and would like to know if there are weaknesses in any given style that might need to be worked on.
        How do you Add Cave Walls?Try using List from the Info menu on the walls you have. See whether it is described as a polygon or as a multipoly. If it is a multipoly you will need to :CC2EXPLODE: it first before things will work. If it is an ordinary polygon please can you upload the FCW file so we can have a look at it and see why it's not working?
        How do you Add Cave Walls?It may be that the new walls are not on the right sheet and layer. Hide all the sheets except the WALLS sheet. If the walls have vanished they are on the wrong sheet and you will need to locate them and use change properties to move them to the WALLS sheet. If the walls are visible then they are on the right sheet, but make sure they are also on the right layer by using change properties. Also, if the shape you converted to walls this way is a multipoly you will need to explode it just once. It's not possible to edit a multipoly.
